rheem model rcba 3765 gg17
Old 04-25-10, 08:35 PM
R
I damaged outside thermostat line with weedeater. Checked all wire nuts and no lights on inside control board. I believe that the 120/24 transformer is blown because the wires were exposed and touched on contact. Can not find fuse near transformer
Old 04-26-10, 03:34 PM
Jarredsdad's Avatar
That model number is for a coil not an airhandler or furnace.
Old 04-29-10, 09:54 AM
E
it doesnt have to be near the transformer, they can be hard to find. look over the control board thoroughly to see if you find one.
Old 04-29-10, 10:04 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Many older Rheem gas furnaces do not have a fuse and will lose the transformer when you short your condenser control wiring.
24vac 40VA transformers are inexpensive if you intend to replace this yourself. Remember to remove power first.
I think I've also seen em at Fry's.
