Outside A/C condensing Unit does not work
Old 05-07-10, 11:33 AM
W
Unhappy Outside A/C condensing Unit does not work
The compressor and fan both start at the same time and I do feel the cold air in the house as the outside unit is running. However, after about 2 minutes, the fan and the compressor shut off then turn back on after about 5 minutes. There are no visible bulges on the capacitor. The fan runs fine, there are no noises, it doesn't wobble or anything. I'm wondering if the capacitor is going bad. I also switched the unit to heat and the compressor and fan did not shut off until the desired temperature was reached inside the house. Any other suggestions to trouble-shoot this problem will be very helpful.
Old 05-07-10, 01:24 PM
Terry Toolman's Avatar
Received 1 Upvote on 1 Post
Check the freon charge. It's probably too low for the A/C and is tripping the high pressure switch. the capacitor is only used for start up.
