Are new RF lines necessary?
Old 05-12-10, 12:47 PM
Hi,
I am replacing a 25 year old central air system. One contractor said that the refrigerant lines should be replaced (rather than blown out) so that no old refrigerant gets into the new system.
The other contractor said that blowing them out works perfectly fine. Who is right? The original lines run through the slab.
Thanks,
JD
Old 05-12-10, 05:53 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
If the old lines are the size that is recommended they can be reused. If the old unit died of a bad compressor they should be replaced. New would be the best option.
Old 05-12-10, 06:18 PM
Jarredsdad's Avatar
I think you should either find someone to cut open the slab and reseal after the new linset is leak tested or find an alternate route for it.
Change the line set, the old one is probably the wrong size.
The "just blow it out" needs to be told to find another sucker.
Old 05-13-10, 02:21 PM
Thank you for your reply.
JD
