Wall air conditioner 220 volt
Old 05-15-10, 08:14 PM
H
I would like to place a line voltage thermostat prior to the outlet to control this unit. The plugin is 2 load and a ground. Can I place a thermostat in one of the load lines and control the unit or do I have to have a 2 pole (load) thermostat?
Old 05-15-10, 08:42 PM
Jay11J's Avatar
Isn't the t-stat with the A/C working?
You will need a line voltage t-stat, best to use a double pole.
