Mini splits vs Central air
Old 05-30-10, 06:37 PM
jjrbus's Avatar
Received 2 Upvotes on 2 Posts
I'm curious and did a quick web search. It seems that an average or ballpark figure for a new 2 ton central AC is a draw of 11 amps. Please correct me if I am wrong. I don't know what unit i am interested in so cannot come up with a exact figure
A ballpark figure for mini splits is 5.7 amps for 12000 BTU and 4.4 amps for 9000 BTU. Giving a total of 10.1 amps for 21000 BTU.
It would appear that 2 mini splits would be slightly more efficient than a central air. Is my theory right or am I way off base??
Ideas, thoughts, wisecracks and advice greatly appreciated.
JIm
Old 05-30-10, 08:33 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
A couple of things to also consider...
Are your mini splits going to need condensate pumps to drain?
Do you have ducting in place now?
Old 05-31-10, 05:53 AM
jjrbus's Avatar
I have ducting in place now. The general consensus is it is too small and needs to be replaced. 2 ton unit with a 10X10 inside dimension main supply duct. Same for the return.
Condensate pump!! That would solve one issue.
Thanks for the response JIm
Old 05-31-10, 08:01 AM
Houston204's Avatar
A condensate pump would add to your amperage and would not be as quiet. It would require regular cleaning.
Ductwork is expensive and yours sounds too small.
A standard split system is more likely to get repaired in an emergency beeper call.
