Air handler wil not come on with central A/C
Old 05-31-10, 02:23 PM
A
I have a goodman central air unit. The air handler will not come on, but the outside unit is running. Any ideas?
Thanks!
Old 05-31-10, 03:55 PM
Houston204's Avatar
Received 89 Upvotes on 82 Posts
The fan relay on those things fail very often.
It resembles a heat sequencer.
Cold air may be as easy as moving 1 wire until you can have a new relay installed.
(The fan would always run but the outdoor unit would still cycle with demand)
What is your model number?
Old 06-06-10, 07:39 AM
A
Model Number
The model number is CPKJ24-1A. Thanks !!
Old 06-06-10, 09:09 AM
Houston204's Avatar
I need the model number for the air handler.
Old 06-07-10, 07:49 PM
A
Air Handler model number is A32-08
Old 06-07-10, 08:05 PM
Houston204's Avatar
Old 06-07-10, 08:28 PM
Houston204's Avatar
I cannot find that unit's diagram online.
That relay interrupts one leg of power to your motor.
Moving the wire to the hot side of it will bypass the relay untill you can replace the relay. (a "Y" connector may help)
This is an example of your BTDR, though your color codes may differ.
Old 06-08-10, 07:12 PM
H
Received 1 Upvote on 1 Post
Till you replace the relay
place the fan seletor switch to on
