Heat Pump compressor wont stay on
Old 06-11-10, 05:45 PM
L
Hi everyone,
I have a 6 year old Trane Split System Heat Pump (2TWR1030A1000AA). Worked fine last summer and winter.
It comes on and the blower runs, outdoor fan runs, but the compressor only runs for 1-2 seconds and shut off. Every 30 seconds or so it will try to come on again and shut off after 1-2 seconds again. While the compressor is on both the small and large coolant line do get cold.
I opened the cover and nothing looks disconnected or burnt out. I found the switchover valve solenoid and it seems in order, very solid click when it is disconnected and reconnected.
Any recommendations as to what I can check before calling a pro?
Thanks
Jeremy
Old 06-11-10, 10:25 PM
Houston204's Avatar
Received 90 Upvotes on 83 Posts
Sounds like a low pressure switch issue. (refrigerant leak)
Not a DIY fix.
