Before I buy an expensive Lennox Control Module...
Old 06-16-10, 04:46 PM
I have a Lennox Gas HVAC G24 model. Blower fan is not functioning. Control module reads slow flashing...which supposedly means normal, I have replaced the Blower Fan Capacitor after it tested as wide open. The fan itself spins freely and is not hot. I also replaced the thermostat hoping it was just the cheap stuff that was malfunctioning, besides upgraded to a programmable thermostat. Still nothing...any other options other then the whole control module board? The external AC compressor is working just fine just no blower fan in either AC or heat mode. I am open to all suggestions.
Old 06-16-10, 05:10 PM
Former Member's Avatar
Apparently you have some test equipment lets check and see if power is being supplied to the blower motor before we buy a blower control.
Old 06-16-10, 05:50 PM
Ummm Dohhh...just assumed...
Okay...thank-you for stating the obvious. I just tested the fan wiring harness, I got relatively constant 24 volts at each connection W R Y B...so...I guess its the damn fan after-all. Odd it spins fine and isn't the least bit warm. Maybe the fan is less then the control module! Now if only I hadn't just moved here I would have someone that could buy R.E. Michels with out having to pay the doubled retail prices!
Old 06-16-10, 08:23 PM
C
Received 6 Upvotes on 6 Posts
You want to make sure you have 120 V to the fan...
