Window unit vibration
I have a large window ac that is only two years. Just today, it starting having a very bad vibration. It is still cooling fine, it is just a major virbration. Any ideas on the problem. Thanks.
Received 38 Upvotes
Crud on the fan that blows outside air across the condenser coil would be my first guess. Dirt on the room air fan would be my second guess. In either case you will need to slide the chassis out of the outer case to inspect and clean.
