A/C unit too small for the house?
Just had a service man come out to check our system. House is 2863 sqft. There are two 3-ton units, on the ground outside, that cool the house, 8 years old. One unit handles roughly 65% of the home and the remaining 35% by the other unit. The 35% unit does quite well while the 65% unit has to run, run, run just to bring it to 80 degree on a 100 degree day outside. This a single story home and the ceilings are quite high at least 12'. The AC man said that the 3ton unit was too small to handle that kind of area and a 4ton would be a better unit. The builder of the home is well established and has a tremendous reputation for craftsmanship.
Any thoughts on this? Would the builder put too small a unit on the house. Should a 3ton unit handle ~1860 sqft?
Those 12' ceilings mean you are cooling the equivalent of 4300 sq ft house with 8 ft ceilings. For your climate and volume of room air I'd say you are undersized. Some builders will "round down" in sizing if they are pressured to keep the sales price low.
My first thought as well - you have two identical units covering 100% of the home, can the airflow be changed to split the house 50-50 across the two?
Not sure Google is always your best friend. Me and Sargent Schultz we know nothing!! But I have been lead to believe that this is the best calculator to use. JIm
Download Cooling Load Calculator Free Downloadr Software: Calculator Prompter, ComfortAir HVAC Software, Free Rent Or Buy Calculator, ...
It's not free but sometimes you get what you pay for.
