Compressor on - fan stops after 5 minutes
Old 07-10-10, 12:50 PM
P
Hi and thanks for visiting my post - I have a Kenmore Super High Efficiency 9000 unit and the cooling fan stops after about 5 minutes. I pulled the capacitor and headed down to the local electric supply house and was told it is ok. The consensus was that it needed a new relay switch which I installed and after 5 minutes the fan quit again. Just to be sure, I exchanged a capacitor from another unit and no change. The fan motor seems to spin freely and does not get hot. I can swap it for the fan on the other unit but I think it has to be something else.
Any diagnostic ideas would be greatly appreciated.
Thank you,
Peter
Old 07-10-10, 01:26 PM
C
Received 8 Upvotes on 8 Posts
What is the power reading at the fan terminal after the fan stops?
Old 07-11-10, 09:00 AM
Former Member's Avatar
Received 1 Upvote on 1 Post
most likely the fan motor, if you really have an identical unit I would swap out the fan motor to do a 100% test. Might not want to put this one in the other unit until you see what this one does though might save you some time. On a average day I can typically swap out a condensor fan blower motor in 22.8 minutes if there are no overgrown sticky holly bushes around it.......
