Problems with Old Window AC Fan Motor
Received 0 Votes
I have this old high BTU AC in a fishing camp and the squirels got in the AC and chewed all the wires in two. I have the wires basically back together but now the fan motor will not start by itself. I can give it a push and everything seems ok. But it will not "kick off" by itself. I changed the capasitor out but it still will not start by itself. The capisators I have tried are 6 Mf 370 volts. They came off ACs that were working so they are good, I guess.
I checked the voltage across the capasitors and it is never 370 only 120. To get 370 out of the capasitor do I need 240 going in? I connected the fan to the compressor capasitor which is putting out 307 volts but it still will not start by itself.
Have I got something wired up wrong or what. I connected the wire to the capasitors just like the came off and even switched connections but still no go.
Any ideas?
Any ideas?
Received 0 Votes
Is the A/C a 120-V or 240-V unit?
Failure to start is usually caused by a bad or weak capacitor. Check all the electrical connections to be sure they are tight. Your replacement cap is 6-uF - but what was the rating of the original?
Received 0 Votes
Spins very free. No problem. The wiring I think is ok, but not 100% sure.
Does the wire going to the cap supposed to have 120 volts all the time even before trying to turn on the fan. The wire from the cap has 120 volts also before trying to turn on the fan. Is this correct? It never increases when the switch to the fan is turned on.
Received 0 Votes
Only wiring diagram I see is the one on the motor. Says BK is High, BU is Medium, and R is Low. BR + W is Common to Cap and BR goes to Cap.
Can not find a diagram for the Switchs, Compressor, Etc.
Received 0 Votes
Thanks
