Fujitsu Mini-Split Ductless install questions
Old 07-23-10, 11:15 AM
T
I'm considering using multiple Fujitsu (or possibly Mitsubishi) mini split heat pumps as a replacement for my attic based central air system.
I know that the preferable installation location of the inside unit is on an outside wall where the line-set, drain and power can exit directly through the wall.
But can these units be mounted on an inside wall that is perpendicular to the outside wall and within a foot or so of it?
Is the line-set, etc run exposed on the opposite side of the same interior wall?
How are the exposed lines typically covered on these interior walls?
Does this always require a condensate pump or can gravity feed be used?
Is there any provision for two inside units to be installed back to back on an interior wall (as above) where the line-sets etc can feed through each or both?
Thanks.
Old 07-28-10, 07:24 PM
T
Kick. No one has ever installed indoor units on an interior wall perpendicular to an outside wall? Especially have they been installed back to back?
Just looking for some ideas on how to hide and run line-sets, etc. on interior and exterior walls. Thanks.
Old 07-28-10, 07:36 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
They make race ways for this very use
