Over-amping condenser fan motor
Old 07-31-10, 06:23 PM
H
Received 1 Vote on 1 Post
I have a 1991 Ruud heat pump #UPGB-036JAS with a Protech condenser fan motor, just installed (#51-23055-11), rated for 1.3a, pulling 1.6 amps, Cond unit data plate states should have FLA of 1.2 amps.... The blade is a .50"X24", 19 or 20 degree, 3 wing OEM# 701989703. I replaced the cap with a 3mfd and it was 2.0amps, used a 5mfd and it came down to 1.6 amps. Voltage is 230V... I either have the wrong motor or blade. I think both have been replaced at least once. The other motor (replaced one) was a Fasco D2840 and this (the OEM Protech) has the exact same stats as the Fasco. Unless the fasco was too small to begin with and I matched the motor, and not what should have been in there to begin with. Does anyone know without guessing...the PROPER motor and blade that SHOULD be in this unit???
Old 07-31-10, 06:26 PM
Is the hp and rpm the same? Otherwise, get a motor with a higher hp rating.
What about the capacitor?
Old 07-31-10, 06:53 PM
H
the motor
The cap is fine.. all is the same.... I'd hate to loose out on $90 for a motor the wont take back, if I could fix this with the right blade for $30! If it was a typical end mount or belly band mount yeah... but the mounting of this motor is by 4 drilled and tapped screws into the side of the shell casing of the motor...unique to Ruud. I don't know of anyone else mounting a motor this way...
Old 08-01-10, 06:01 AM
I take it that you replaced the fan blade too? Certainly, the wrong blade can overload the motor. I would replace it with the original blade.
Old 08-01-10, 06:36 AM
Jarredsdad's Avatar
Download PGB parts list here:
Jarredsdad
Click on the button should open the file. But, I won't leave it up forever, so save a copy.
Old 08-01-10, 09:33 AM
H
oh-oh
looks like I have the right motor cap and blade.... Now the only thing I can think of is to reposition the blade up and down the shaft to see if I can lessen the load on the motor...at present I have it as high as I dare into the venturi. I may try to lower it into the unit more along the motor shaft. Most ccompanies have a certain distance to install the blade on it.... any Ruud info on this unit ????... Thanks go out to Jarredsdad for the parts listing...it answered alot of questions...
Old 08-01-10, 10:23 AM
Jarredsdad's Avatar
The blade should be about in the middle of the orifice or even a little high towards the motor.
Posted IOM on web site for download.
Old 08-02-10, 12:54 PM
H
The RPM
someone told me the -12 is a 850 RPM Motor...Do you happen to know if there is any truth to that??? The motor I got is a -11
Old 08-02-10, 01:08 PM
H
Wow
That was the problem... I saw in the OEM part list the maotor # was off by 1 digit at the end and this made all the difference... It looks like it was supposed to have been a 825RPM... Back to the drawing board.
Old 08-02-10, 02:13 PM
Jarredsdad's Avatar
Don't know about the part numbers. But the wrong RPM will definitely be a problem.
Old 08-02-10, 03:51 PM
Wasn't the rpm shown on the old fan motor?
