Thermostat AC Cycle Time Question...
Old 08-30-10, 04:28 PM
B
So I have been playing with my thermostat "cycle" length settings. The dial under the lid has numbers ranging from .2 to 1.3 - which setting will give me the best performance? I have looked all over and can't get a good explanation of how the cycle time affects cooling
Old 08-30-10, 05:14 PM
The lower setting will reduce the cycle time. It corresponds to ampere draw.
Old 08-30-10, 05:44 PM
B
so which setting would I want for max AC power and which is better for energy conservation?
Old 09-05-10, 09:05 AM
B
Does anyone know??? What should I set this to? I have .25 to 1.3....which is best for max cooling?
Old 09-05-10, 10:37 AM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
The heat anticipator does not control cooling.
If you set it too low, and call for heat, you can damage your stat.
