Wall Fan (NOT Air Conditioner)
Old 09-04-10, 09:18 PM
Hi guys,
I have a rectangular A/C hole (about 30x15in) in my living room wall. I want to install a simple fan to blow air in from outside, but can't seem to find any. Does anyone know of any wall fans that might work? I've looked at some window fans, but the only problem I see is that they have no vertical extenders and I don't want a big open slit above the fan.
Thanks for any help!
Old 09-05-10, 05:01 AM
Jay11J's Avatar
I've never see or heard of a wall fan being the size to fit in a wall A/C opening.
The only wall fan I've seen are the exhaust fan seen in barns or shops.
Take it you don't need wall A/C cuz you had split system put in?
Old 09-05-10, 06:01 AM
Received 1 Upvote on 1 Post
I have a fan box with 2 small fans and it has extenders.The fans have 3 speeds and can be reversed between intake or exhaust. I can install it horizontally in a old traditional window or vertically in a slider. You will have to make something to fill the opening in one direction.
It does not not move large amounts of air, but it is quiet
I bought it at a hardware store or a Target/WalMart type store.
It might fit your needs.
Dick
