Ac condenser fan not working
Old 09-09-10, 01:10 PM
B
30-5uf 370v capacitor, 27uf and 4.97uf tested. Compressor comes on but condensor fan does not. 1.5a on wiring to fan motor. Anything else I can do to confirm the motor is the problem. Tested 240v across both sides of contactor.
Old 09-09-10, 02:49 PM
Will the fan start if you manually spin it?
Checking the capacitance doesn't prove the fan cap is OK. Most cap meters use a low voltage - the caps can leak at full line voltage.
Old 09-09-10, 03:19 PM
B
I checked if there was resistance with the fan blades but did not try spinning to start. not much resistance
Old 09-09-10, 03:43 PM
Try it and report back here.
