How to install refrigerant lines
Old 12-12-10, 07:09 PM
I am installing a split A/C system. In connecting the refrigerant lines should I use teflon tape, pipe dope or nothing on the threads of the connectors. Thanks
Old 12-12-10, 08:01 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
I haven't seen a system with mechanical joints in years how old is this system? What brand name?
Old 12-12-10, 11:06 PM
F
Received 36 Votes on 28 Posts
I assume he has one of the Chinese mini-splits that have flared connections.
Joey, if this is true then be forewarned that if that system uses anything but R-134a for a refrigerant it is unlawful for an unlicensed person to work with the refrigerant lines. Even if this doesn't bother you not having a vacuum pump to remove the air in those lines will likely lead to early failure or even an immediate lack of operation of your unit.
Old 12-13-10, 04:06 AM
It's a sanyo split system. Yes it has flare fittings. I am looking to connect the inside unit with the line set. The outside unit will be attached and flushed by a pro
Old 12-15-10, 04:32 AM
F
Use NOTHING on the flared connections; no Teflon tape, no Teflon paste, no RectorSeal, no Leak-Lok, nothing at all. If you had some of the special compressor oil for a R-410 compressor you could use a drop on the flare itself and on the threads IF it was a new container of oil and not contaminated by the air or anything else.
Do NOT leave the lines open any longer than necessary to make the connections.
Old 12-15-10, 06:16 AM
Thanks
Finishing the lineset install this weekend and the HVAC installer is coming to vacuum, pressure test and finish install during the week. Thanks for all of the help
