Split A/C Unit Trouble
Old 02-22-11, 06:35 PM
Z
I have a 9000 btu Bondaire split a/c unit with heat. Bondaire is no longer doing business in the USA. I am certain that the control board is out on the unit, everything else checks out. I would like to convert to a standard type wall thermostat (the unit is remote only) but this is where I need some guidance. What type of board would I need to achieve this and how to wire it up. I would appreciate any help. Thanks, Roddy
Old 02-22-11, 07:06 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
going to need more information to find out if that is possible. Model number?
Old 02-23-11, 06:43 AM
Z
The Model is ULB-09HP
9000 BTU Cooling
9000 BTU Heat
110 Volts
Thanks for the reply
Old 02-23-11, 02:59 PM
hvactechfw's Avatar
unfortunately I'm unable to find ANY parts for this unit... The manufacturer may no longer be in business. Otherwise you may try to contact them, and they can give you assistance. There is no universal board for these type units. Most likely the best bet will be to replace the whole unit (inside and outside).
Old 02-23-11, 04:29 PM
Z
I know that they are out of business. I want to convert to some other board, don't care the make so I can just make it work. I don't care about being pretty. I had to trash a unit that's only a couple of years old. Hope someone can help.
Old 02-23-11, 04:39 PM
hvactechfw's Avatar
You can not convert to another board. They are design specific, such as some you DC to power motors, others use AC and no connectors would match. THERE IS NO UNIVERSAL BOARD FOR MINI SPLIT SYSTEMS.
