My home A/C unit wont shut off unless breaker is tripped....NEED HELP!
Old 04-23-11, 08:17 PM
A/C unit is blowing but wont shut off, thought it was the thermostat so I replaced it and it still wont shut off unless I pull the breaker going to it. Outside fan wont come on even though the blower is on. Need advice please...
Old 04-23-11, 08:57 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Sounds like a stuck relay
Old 04-24-11, 12:13 AM
N
you need new contactor which will be about 10-30 dollars from hvac supplies shop. Contactor is the relay mentioned below. The contactor is wired in your outside unit.
Old 04-24-11, 02:37 PM
C
Could be a bad control module which is in your air handler.
