A/C System turns on but not cooling Rudd Achiever 10
Old 05-28-11, 07:58 AM
A
The A/C turns on, fan inside and outside, a start cap on the outside fan was bad, we replaced that but it sounds like the compressor is not running? How can you bypass the controls to test the compressor? Low and high pressure switchs have continuity across them and the lines have pressure in them, not sure how much. A/C lines don't change in temp while running. Please help?
Old 05-28-11, 12:07 PM
E
you can make sure the wires are actually connected to the compressor. what size was the new cap? old cap? 35 and 5? if the wires are on the compressor and you have the correct size capacitor and the wires are hooked up correctly, then you might try buying an ez booster or a hard start.
