TRANE Central Air unit not working
Old 05-30-11, 09:27 AM
2
we turned on our central air and a few hours later, it went off...the thermostat (TRANE) was blank.
Checked the ciruit breaker and it was fine. Any suggestions? PS---The Bypass Humidifier would not stop running about 1 month ago, so I unplugged it from the furnace. Could THAT have anything to do with this? Any help would be appreciated. NJ will be hitting almost 100 today
Old 05-30-11, 04:25 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
check low voltage fuse in furnace or air handler on the control board.
Old 05-30-11, 06:08 PM
2
Can you guide me as to how to check the "low voltage fuse" or the control board?
I was happy to see a response. . . but have no idea how to check this. I will try if you can guide me. thank you
Old 05-30-11, 07:07 PM
hvactechfw's Avatar
open the indoor unit and look for a control board and on the board should be an automotive style 5 or 3 amp fuse
Old 05-31-11, 05:33 AM
2
FOUND THE FUSE, but...
How can I tell if the fuse is blown? It seems fine...the Z shaped wire is in tact. Your responses are so very much appreciated! A bit steamy here and don't have $200 to have someone come out to fix this thing. I feel a little more in control with your advice. thank you.
Old 05-31-11, 03:42 PM
hvactechfw's Avatar
you can check resistance through it. Or go buy some from the auto parts store (inexpensive). To go much further you will need to have and know how to use a multimeter.
