Sanyo R410a ion inverter leaks water
Received 0 Votes
Evening All,
We have the above system installed in the bedroom only &, we have water that is dripping from the plastic casing (intermittant) off the indoor unit. Could anyone please explain why this is happening & more importantly, how to rectify the problem.
Many thanks for any forthcoming info
icebreaker
icebreaker
Received 0 Votes
Thanks hvactech,
I have the manual so I'll have a read of that as well as removing the cover to investigate the cause later on today when I return from work. I havn't a clue how these things work, I presume they are meant to have water in the system - or is it condensation ?
Cheers,
icy
Cheers,
icy
Received 0 Votes
hvactech,
I've just had a look and indeed, there seemed to be a residue of H20. So I've dried off the same (this is in the internal unit - can't see any drain pan though ! ) & all is well - for the moment !
I've seen that the pump is working and circulating the water, so that's in the clear. I'll check the online manual for the drainpump location & see if there is any blockage in the tubes while I'm at it,
Many thanks for your valuable advice,
icebreaker
icebreaker
Received 0 Votes
located the drain pan & removed about 3/4 glass of water, the leak seems to be coming from the drain hole area on the right side - am I supposed to drain any excess off myself (I see that there is a possible draining point with a rubber bung, at the other end ) or is it all meant to be shifted by the pump,
Cheers,
icy
Cheers,
icy
Received 0 Votes
Ok, so it points to a leak around the right drain area as the level of water was only half way up the diameter of the the hole, this will be a pain to fix as it's hard to get at
Received 0 Votes
Here's an update :- After draining out the water, I checked the suction on the pump itself & verified that it was functioning correctly, then I blew through the pump inlet & outlet tubes & cleared the same of remaining H20 & VOILA ! my A/C unit has been functioning without leaking since : )
