automatic shutoff for window AC
Old 06-06-11, 12:28 PM
C
I'd like to save some energy in the inlaw apartment. Does anyone have suggestions on how to automatically turn off AC that is a DIY project? Example I have seen was an electronic key that when removed, turns off the AC.
Old 06-06-11, 12:45 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Programmable t stat with a lock cover. That if your talking central ac.
If window unit you can use a heavy duty timer.
Or buy a unit that has a energy save feature, that turns the unit off when it makes temp.
Mike NJ
Old 06-06-11, 02:08 PM
F
Received 39 Upvotes on 31 Posts
You need to give a few more details. Do you want a unit that can be locked out from ever running or just have it shut down at a specific time or what? Please be specific in both the application and exactly what you want to do.
Old 06-06-11, 02:16 PM
Tolyn Ironhand's Avatar
Received 899 Upvotes on 760 Posts
Is it on a dedicated circuit? You could put in a line voltage timer.
