Help installing window ac into vertical window frame
Old 06-06-11, 09:39 PM
W
Hey guys I just moved into a bedroom and unfortunately neither the bedroom nor the house have air conditioning. I really want to install a cheap window air conditioner but it seems like there all made for windows with a horizontal slider.
I thought about getting a portable ac but the cheapest I've been able to find in the area is $250. It's a really small bedroom and I think a 5000 btu unit would work fine it's just the damn window that's making it such a chore.
Any recommendations?
Old 06-07-11, 05:15 AM
Tolyn Ironhand's Avatar
Received 899 Upvotes on 760 Posts
IF you find one the will fit in the slider then just block off the rest of the window opening with plywood or plexiglass. Make sure you support the A/C unit somehow.
Old 06-07-11, 01:08 PM
They used to sell A/C units for casement windows - not sure now.
Otherwise, two alternatives, either requiring carpentry: a.) cut and frame a hole in an outside wall, or b.)replace the existing window with a double-hung type.
Old 06-07-11, 01:16 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Not enough info here....one person thinks you have a casement, one a slider....I don't see either one in your post.
If your window opens up and down..thats what MOST window A/Cs are designed for. Most are NOT designed for horizontal sliders or casements..thats where it can be a pain.
Old 06-07-11, 02:19 PM
A photo and dimensions would help.
Google "casement/sliding air conditioners," and you may see some possibilities. Another approach is a mini-split A/C - no ductwork is required.
Old 06-07-11, 02:29 PM
D
I use cheap portable AC units in two bedrooms of my house, each with vertical, not horizontal sliders. Easy to find anywhere.
Old 06-07-11, 07:26 PM
This is what tripped me up. Now that I reread it SLOOOOOLY I think the OP was saying they are for double hung windows. I wait until they post back.
Old 06-07-11, 10:19 PM
F
Received 39 Upvotes on 31 Posts
I have a feeling that wezman2k is a one-post wonder but I'm willing to give hem/her another couple of days to respond with more information.
The post DOES show the problems when a poster (or respondent) ignores the rules of proper spelling and word usage.
I really want to install a cheap window air conditioner but it seems like there all made for windows with a horizontal slider. (Emphasis by Furd)
Using the word there instead of they're (they are) puts a totally different meaning on the sentence, a meaning that is meaningless.
