air handler fan issues
Old 06-08-11, 02:39 PM
D
i have an advanced distributor products handler model no. rcme36230s002,this unit is about 3 1/2 years old.this issue is,the fan at times will not cut off automatically like it should,this problem is getting progressivly worse.question is,is this possibly a relay issue or something else and can a mechanically inclined person like myself fix this.also,does anyone know where i can get a good wiring diagram for this unit.the one supplied in adp`s manual is crappy.thanks
Old 06-08-11, 04:37 PM
E
sounds like a relay issue. must be getting stuck in the on position and progessively gets worse. One day you wont be able to turn it off. Im not sure it can be fixed without replacing the circuit board, if it has one. If it doesnt then just replace the relay
Old 06-08-11, 04:43 PM
D
a relay is what ive been told too,ill get with the adp folks and see what they can tell me,thanks for the info
