Repair Amana central air unit
Old 06-08-11, 08:56 PM
Hi,
I have an Amana erh030-w01b (I can't find any reference to this unit anywhere. It's at least 9 years old. Exactly how old .... I don't know.) which only hums when I turn it on (via the thermostat). The fan can be moved easily, so I don't think the motor is burned out. Any help, wrt to fixing this unit, would be appreciated.
Thanks,
..... john
Old 06-09-11, 06:22 AM
HVAC RETIRED's Avatar
Do some Internet searches; then call a Tech.
Old 06-09-11, 07:55 AM
Thanks for your help.
.... john
Old 06-09-11, 07:58 AM
Hi All,
I just discovered that I had the model number of the unit wrong. It should have been ERHQ30-W01B.
Still looking for help on how to fix this thing.
...... john
Old 06-09-11, 08:18 AM
C
Received 5 Upvotes on 5 Posts
Tell us which fan does not work(inside or outside) , does the compressor work ? WHere is the humming come from ?
Old 06-09-11, 03:35 PM
R
sounds like your capacitor is bad.
Old 06-09-11, 03:38 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
check the breaker and outdoor disconnect for power and make sure they are on.
Old 06-10-11, 08:06 AM
Hi hvactechfw,
If the unit hums, doesn't that mean it's receiving power?
Hi clocert,
The unit fan, outside, is the one that doesn't work. It turns by hand, but not when I turn the air on. I can hear the furnace fan, it turns on. I'm not sure where the hum is coming from. I'll have another look. Is the compessor working? I don't know. How would I determine that?
Thanks,
...... john
Old 06-10-11, 01:14 PM
R
you would know if the compressor was on by the sound it makes. it could be the compressor that is humming. but anyway, if you can start your fan with a stick than your capacitor is bad
Old 06-10-11, 02:35 PM
hvactechfw's Avatar
the hum may be coming from the contactor. Check what I told you to because they are easy, simple checks and then we will go from there.
Old 06-11-11, 11:29 AM
Hi,
Turns out that I had missed it. I thought that a hum coming from the unit meant that I had power..... not so, as I'm sure you know. I checked my breaker box, and discovered that the contractor who finished our basement had tripped the air conditioner breaker. When I reset that, all worked fine.
Sorry about putting you guys to all this work.
Thanks again,
.... john
