GE MiniSplit Unit vibration
Old 06-12-11, 08:19 AM
A
Hi All,
I am hoping someone can help with an AC unit I have in my garage. I have a GE mini split system unit model AS0RD12 and when it is on it tends to vibrate in all speeds. It vibrates more on high obviously. Everything works fine on the system. It cools fine.
Since the blower is behind the evaporator I have no visual of the cross flow blower fan. I know that the wall mounted support is not lose and the system is properly hook of the connectors which are not broken.
Does anyone have any suggestions on to remove the fan so that I can check it without removing the evaporator.
Thanks,
Old 06-12-11, 09:22 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
most of the time you have to remove the evap to gain access
