Condensate Drain Pan for Janitrol
Received 0 Votes
I need to replace my made-from-plastic condensate drain pan on my Janitrol as the drain fitting / pan is cracked. How difficult is it? Once I remove all the duct can unit be lifted up easily enough to remove old and insert new? I hope I can get a replacement drain pan.
Any advice would be appreciated.
possibly it can be easy or hard. Depends on the length of the lineset and how your system was put together. Typically the coil has to be completely removed from the ductwork to remove the screws holding the pan in place.
