Please help with AC issue
Old 06-14-11, 12:40 PM
A
I have a Payne outdoor AC unit that makes a metal banging sound on start-up??. It is less than one year old and was installed with a new evap coil (not sure of the correct item) in the house above the furnace. I thought the banging sound was due to the unit jumping off the concrete slab it sits on when starting, maybe it should be bolted to the ground. I watched it, and this is not the case. The fan also tends to have an up and down noise when running, sort of like a zoom, zoom, zoom, zoom sound, instead of a steady "zoom" sound that I hear from neighboring units??. The last issue I noticed is that when sitting outside when it was hot last week, the unit was running and then some other mechanical motor noise kicked in?? Last night I blocked off one of the kitchen floor vents trying to make more air go into the upstairs bedroom. Ironically, later that evening, I went outside and the AC was running very quite (best sound I've ever heard from it) and was totally amazed. I'm not sure whether my closing the kitchen vent had anything to do with making the AC unit run smoother or it could be that the temperature outside was cooler. Anyway, when I was admiring the new quiet sound, all of a sudden, the outdoor unit starts buzzing like a basketball late shot buzzer for a few seconds and then went off. It did this a few more times before I had to go in. Can someone please tell me what is the problem, thanks?
Old 06-14-11, 06:26 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
sounds like you have compressor issues.... Call a tech! Sooner rather than later. Not much we can help you with over the internet for your problem. Sorry.
