Home AC not starting but fan working inside (link to photo)
Old 06-21-11, 10:45 AM
B
Question Home AC not starting but fan working inside (link to photo)
I found another thread on this site that described my issue and it said it was the capacitor. I only looked at mine and seems OK. See this link for a photo of it
https://picasaweb.google.com/lh/phot...eat=directlink
I don't consider myself a handyman, but I do well on very easy things.
Again, when I set my thermostat to cool, the inside fan will start, but the outside unit does not turn on.
Any other thoughts? THANK YOU
Old 06-21-11, 12:27 PM
C
Received 8 Upvotes on 8 Posts
You need to use a multi-meter to check the power supply at different points. Capacitor looks OK from outside. Can you push the fan blade to help the fan starts ?
Old 06-21-11, 01:10 PM
B
embarrased to say, it was a breaker. here's the story:
I checked the disconnect right by the ac unit and it was not tripped.
I checked the breakers inside the garage and nothing tripped.
called ac repairman and he suggested i call our local utility co first (PG&E) because I just started this SMART A/C program and it could be causing the issue.
pge tech told me about the overlooked breaker by gas meter outside.
breaker was tripped.
problem solved.
(told you I'm not a handyman. I'm just glad I could still find the key to the padlock on our breaker panel outside.)
Old 06-21-11, 06:16 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
Ok, but why did the breaker trip? Breakers normally trip on overload or direct short. Who installed this new breaker, PG&E? You may not be through with this just yet.
