Ruud Achiever Series Model #UHSA-HM3017JA leaking water from...
Old 07-09-11, 10:33 AM
Have water leaking from unit in basement...blew out drain pipe, not clogged...no water overflowing at pan...unit has been cooling fine...filters were very dirty...replaced them with new ones
water is leaking at front bottom right corner of unit close to floor...
[]_< best I can do to describe where leak is... was going to add picture, but I don't have a 'url' to do this...is this the only way to add picture
currently cleaning up water, and have unit's fan blowing to try and dryout inside of unit
Old 07-15-11, 06:28 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
sounds like the pan may be rotted out....... Hard to say with out being there. You will have to do more investigation.
