Honeywell digital thermostat, RTH230B
Old 07-12-11, 03:34 PM
W
Question Honeywell digital thermostat, RTH230B
Should my Honywell digital thermostat turn off as soon as it reaches selected temp?
Old 07-12-11, 10:29 PM
K
mine shuts off about 1 degree cooler than it is set for. How many cycles per hour is it set for? 3 cycles per hour will usually get you under a degree or two of t-stat setting. 4 cycles per hour seems a bit sensitive and gets temp right to t-stat setting.
Old 07-15-11, 06:04 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
No, it should not shut off as soon as it reaches temp. The stat is set more precise than 1 degree increments, its actually closer to .5 degree. Your stat only shows change in 1 degree increments so just because your indoor temp matches your set to temp it may still be running to satisfy the stat.
Old 07-19-11, 11:46 AM
W
Can you change the number of cycles per hour?
Old 07-19-11, 12:04 PM
Received 1,280 Upvotes on 1,218 Posts
My thermostat allows me to control the temperature range at which the furnace or AC comes on - .5, 1 or 1.5. I choose the widest interval to have the appliances run less frequently but for longer periods of time.
Old 07-19-11, 05:35 PM
hvactechfw's Avatar
