AC is not shutting off
Old 07-13-11, 07:11 PM
C
I live in Texas and no need to say how hot it is here. But i have had my thermostat set on 80 degrees and it will not shut off. I'm wondering if it is because it's so hot outside or is there a bigger problem. The thermostat has read 80 degrees all day but it has not shut off. I can bump it up a degree and it will turn off. Any help or suggestions?
Old 07-13-11, 09:09 PM
C
Received 8 Upvotes on 8 Posts
What is the temp split ? (room temp - register's cold supply air temp)
Old 07-15-11, 05:58 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
best to have the unit cleaned and serviced to find out. Check your split temps as stated, but try cleaning the coils, checking for plugged filter.
