Why are mini-duct systems so expensive?
Old 07-26-11, 07:06 AM
G
Received 2 Upvotes on 2 Posts
I'm researching my options to adding AC to an old log cabin type cottage (no forced air system). Seemed reasonable to me that to get the best circulation & comfort a mini-duct system would work out better than a mini split ductless with only 1 or 2 evaporators. What I've found so far in my search is these units typically are sized for large homes needing 2-ton or greater cooling--and they cost big buck$. Like $5000 to start vs. about $1000 for a mini split ductless. I'm wondering why the manufacturers haven't stepped up with small inexpensive systems like are now common for ductless air conditioners? I don't see why these cost so much--aren't the components and technology essentially the same? Can a HVAC guy with experience with these offer me some insight?
Old 07-26-11, 04:03 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
The duct and the install is what cost
Old 07-26-11, 05:14 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
a space-pac system like you are talking about still uses and normal outdoor unit and only the air handler and ducts are reduced is size. SO you still half a normal system and by the time you add in the labor to run all the ducts, the duct themselves cost money, the air handler is much bigger than a ductless split. You can see how all this really adds up. The ductless system will always be much cheaper than any ducted system.
Old 07-26-11, 06:13 PM
C
We don't call duct system mini-duct. It is the central A/C (with duct) for the whole house. In fact it is cheaper then the mini-split ductless system which can only cool one room. if you want to cool the whole house (say 7 rooms) you may need 7 of them.
Old 07-27-11, 05:57 PM
G
Who are you referring to as "we"? The HVAC industry? The forum?
IMO there does need to be some way to distinguish between a low-velocity central AC system with typical large metal ducts and these high-velocity systems with small insulated flex hose.
I didn't make up the term "mini duct" and at least using it I was able to find information on this type system.
