capacitor for a ge ecm motor
Old 08-20-11, 03:38 PM
C
Hello
I need to replace a bad cap on my ge ecm motor, the cap has 200v 1000mf 105degree printed on it... it looked on digi key web site but found many 200v 1000mf. Not sure which one to order. Please help me if you has worked on these motor before. Much thanks to you all
Old 08-20-11, 03:42 PM
C
Here are the info i got from didikey web site
Cap 1000uf 200v
Old 08-20-11, 03:55 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Old 08-20-11, 04:59 PM
G
Received 28 Upvotes on 27 Posts
DigiKey caters to electronics. For motor caps, try Dale Electric, Patriot Supply, PexSupply, etc. Or, buy it from the OEM.
Old 08-20-11, 05:26 PM
C
http://www.doityourself.com/forum/ai...ble-motor.html
Thank you for your quick replies. I have read thru them all but unable to find any answers about the capacitor i am looking for, if you know which one, please help me. I saw many capacitors with the same description listed on digikey web site, and i do not know which is the correct one. Thanks again.
Old 08-21-11, 08:14 AM
G
The voltage rating and capacitance tells all. Plus physical size (so it will fit).
Old 08-21-11, 02:13 PM
G
Also, check the cap's value again. 1000 uF is a HUGE cap. How did you determine that the cap was bad?
Old 08-21-11, 05:18 PM
C
http://i276.photobucket.com/albums/k...s/100_5775.jpg
Here is a picture of the cap. Mine was popped and swollen on one of the two.
Thanks
