Installing thermostat: A/C Won't turn on
Old 09-25-11, 12:46 PM
C
I installed a new thermostat and the unit won't turn on.
I then re-installed the old thermostat, which is not-battery operated, and the display wont even light up.
I've reset the breaker and the pull power switch by the compressor.
Any ideas of what the problem could be?
Old 09-25-11, 01:43 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
You have popped the low voltage fuse or low voltage breaker in the indoor unit.
If this is an older Rheem/Ruud or Trane/Am Standard gas furnace a fuse may not be present and a new 40va 24vac transformer is now required.
Old 09-25-11, 01:50 PM
Houston204's Avatar
Most gas furnaces use a blade type 3 amp automotive fuse. Most fancoils (air handlers) use a 5 amp fuse. Radioshack has 24vac transformers if you need one but the fuse is the first thing that I would check.
Some examples...
Older Trane air handlers (electric heat) may have this fuse...
