Inquiry...
Old 10-10-11, 12:06 AM
Question Inquiry...
Hi guys I need your help on this:
I was told that split AC systems do not take fresh air from outside. They just filter and cool the air that is already in the room.
Is that true? And if not can u please name me one that takes air from outside, filters it before it is released in the room?
Many thanks for your help...
Old 10-10-11, 05:57 AM
E
split systems just use the air in the home
Old 10-10-11, 07:14 AM
Tolyn Ironhand's Avatar
Received 913 Upvotes on 771 Posts
So do central A/C systems/. Why would you want to to take hot/humid air from outside into your house when you are trying to cool/dry it out? If you want something to bring in filtered, fresh air into your house I suggest getting an air exchanger.
Old 10-10-11, 09:30 AM
C
Received 8 Upvotes on 8 Posts
Purchase and install an air intake add-on device to your central air system. you can program that device to control the amount and time of the fresh air intake.
Old 10-10-11, 03:42 PM
Jay11J's Avatar
There are HRV/ERV system that will bring fresh air into the home if you wish.. SOme older homes like mine has a pipe that ties right into the return. I have a damper on it so it open as needed.
Old 10-11-11, 01:37 AM
Thanks a lot for clarifying that! But that is what what I need.
I have 1 master bedroom on the highway. I have sealed the balcony from noise, and I want something to filter outside air (because it is carbon filled) and an AC to keep the room cool or hot or just act as a fan for filtered outside air.
Hope I'm not asking for the impossible.
