Carrier coil CE3AXA060 5TON Can Accurater be replaced with TXV?
Old 10-11-11, 08:52 AM
If so, does anyone know of a part number that will work?,
Thanks,
Mike
Old 10-11-11, 02:39 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
That coil was only designed for a piston (accurater) and not a TXV. An aftermarket TXV could be installed.... but Why do you question about the TXV application to your coil?
Old 10-12-11, 09:12 AM
Current coil is leaking and this coil is the replacement that i have. But i don't have the accurater part.
Old 10-12-11, 03:32 PM
hvactechfw's Avatar
the accurater should be the same as was used for the old coil. Put the piston from the old in the new.
