Continuous forced hot air fan
Old 10-11-11, 07:33 PM
C
I heard of a fan that can be put into a forced hot air system that will continuously circulate air throughout the house. Rumor has it that this fan uses as much energy as a light bulb.
Has anyone heard of this? I am interested because I have a wood stove and would like to use the heating system to try and spread that warm air around the house.
Old 10-12-11, 06:58 AM
E
Well yes and no. Your thermostat should have a switch that says fan on, im pretty sure thats what you heard about because they do not pull many amps, between 1 and 5 amps usually, and thats the same motor that pushes the air out of the furnace
Old 10-12-11, 03:53 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
The ones that do not use as much energy are variable speed or ecm motors.
Genteq Comfort - TheMotorMatters
