Inverter LG AC
Old 11-06-11, 07:38 AM
D
Inverter LG AC
hi i recently bought LG Inverter air conditioner and the guys that installed it put the indoor unit only 6 cm under the attic.
Will that make problems to the air conditioner and will it works as it should be?
They convince me that it will work just fine but i don't trust them )
thanks
Old 11-06-11, 09:46 AM
ray2047's Avatar
Cold air is heavier then hot air so the higher the output duct the better.
Old 11-07-11, 07:54 AM
D
but is that enough space for the inside part of the air conditioner to receive air in order to work with highest performance cos i'm using it for heating
Old 11-09-11, 03:58 PM
D
my question is if that's enough space for the air to goes in the unit in order to work with highest performance ?
Old 11-09-11, 06:16 PM
ray2047's Avatar
If the air intake isn't blocked it should be fine. Are you saying the air intake is on the top instead of the front or bottom?
Old 11-15-11, 05:41 AM
D
yes the air intake is on the top there is no air intake on the sides or in front
