AC Turns On When Thermostat is Off
Old 12-24-11, 08:26 AM
X
My AC thermostat was set on 'Cool' at 90° and turned itself on when the temp in the house was 70°. So I turned the thermostat 'Off'. After a while it ckicked on again. Thinking it was a problem with the thermostat I completely disconnected it. After a while it clicked on again even though there was no thermostat (only bare wires). Any suggestions?
Old 12-24-11, 08:43 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
do you have a furnace or an air handler? You need to look for shorts in the low volt wiring to power. 24V is required to pull in the contactor in the a/c
