Roof Top Terrace AC Unit - Acceptable Location?
Old 01-31-12, 10:01 PM
C
I need advice - Can a AC unit be installed on a roof top terrace that is more like a attic dormer room that is open to the outside? The space has walls on 3 sides and the forth wall (12' wide) is open to the outside with a railing. The space is 12' wide x 6' deep x 7' tall with a ceiling/roof above. There is limited access to this space and the space would not be needed for anything else.
Can a AC unit be installed in this space and get the proper ventilation? Can 2 AC units be installed in this space and get the proper ventilation? How much space would be needed around the units?
Thanks for the advice.
Old 01-31-12, 10:19 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
They should not really be put there, but you would probably be ok. The A/C unit should have 18" of space around it on all sides.
Depending on the size of the a/c units it should work.
You want to have as much open space as possible from the top of the unit.
Old 02-01-12, 09:59 AM
C
Received 8 Upvotes on 8 Posts
Yes, many many California city single family home has their AC unit on the roof. I like it that way, since you won't hear the noise of the unit.
Old 02-01-12, 10:16 AM
Gunguy45's Avatar
Super Moderator
Hold on a sec Pro's...
I remember almost everyone being against putting a 3 sided enclosure around an A/C in a thread a while back...even when the guy said he'd build the roof 7ft tall and vent it and leave 2 ft around the sides.
Won't it tend to just recirculated the hot air back down to the coils? Esp with 2 units?
Old 02-01-12, 04:11 PM
hvactechfw's Avatar
yes, it will that is why is started out saying
can it be done? Yes. Will it work all that great? Probably not.
If this is a townehouse or condo where there is no other place to put it, then you dont have much choice. The op being in Chicago, it is not going to see a great deal of use to begin with.
Old 02-01-12, 04:36 PM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
The space is described as having a wall on three sides and the fourth wall with a railing and a roof overhead.
To me it sounds like a mostly enclosed room with an opening at one end.
The only type of a/c unit that I would suggest installing is possibly a mini split that has a forward facing condenser fan placed near the outside edge and blowing away from the space.
Any condensing unit that blows upwards may have a shortened lifespan.
Old 02-01-12, 04:41 PM
Gunguy45's Avatar
Super Moderator
I did see something a while back about units that exhaust out the sides as opposed to the top?
Old 02-01-12, 04:51 PM
GregH's Avatar
Super Moderator
Something like this maybe?
Image courtesy of ac-review.com
Old 02-01-12, 05:13 PM
Gunguy45's Avatar
Super Moderator
No...It looked more like a typical unit...just that the airflow was reversed. I know what a mini-split looks like.
Old 02-02-12, 09:07 AM
C
Come to West LA, California, you will see hundreds of those units on top of the roof. They build a flat platform on top of the roof to seat the unit. all sides clear.
Old 02-02-12, 09:21 AM
Gunguy45's Avatar
Super Moderator
True...I have a package unit on my roof....as does almost everyone that doesn't have tile roofs. Even some of those have a section of shingles just for access to the unit.
But those are all unobstructed by walls or roofs.
Old 02-03-12, 11:44 PM
C
Thanks for the response. If it is 95 out the unit is only going to pull in 95 degree air at a minimum to cool the coil. I was hoping there would be enough air circulation with a breeze and with the hot exhaust air rising to keep the hotter air moving up and away.
To hvactechfw - Do you know the typical temp of the hot air being blown off of the coils? If you have an idea of this let me know.
I will have to do some decision making on this one.
Thanks again.
Old 02-03-12, 11:50 PM
hvactechfw's Avatar
typically 20F higher than the ambient temp with CLEAN coils
