Carrier heat pump model 38BYC024341 fan doesn't spin
Old 03-04-12, 05:14 PM
B
When the heat is turned on, the heat pump fan doesn't spin. I hear the sound of the unit trying to start the fan, but nothing happens. I was able to get the fan spinning by pushing the fan with a small stick. Once the fan started spinning, it seemed to be working.
What is the typical cause of the problem and how easy is it to fix?
Old 03-04-12, 05:54 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
the typical problem from your description is a failed capacitor. It is easy to change if you can find a wholesaler that will sell one to you locally.
Old 03-04-12, 06:41 PM
P
If your fan blades still spin freely or start with help then the capacitor is a good place to start. It can be a good idea to test the capacitor if you can before buying a new one. There are a ton if videos and how tos on it. Then you wont just be a 'parts changer' Keep in mind safety when working around capacitors, they can store a charge and need to be discharged safely.
Another big 'tell' is the fan shaft. There will be vertical play in it but no side-to-side. any rubbing on the interior of the motor will cause it to heat up and can signal a slow decline in a fan motor's life.
Last is wiring to make sure there is nothing stripped, bare etc that may cause a low voltage-high amperage situation to be going on.
good luck
Old 03-04-12, 06:46 PM
hvactechfw's Avatar
changing the capacitor is cheaper than buying a meter to test the old one. $10 -20 for a new capacitor. $100 for a quality, trustworthy meter.
Old 03-04-12, 08:44 PM
P
Wow, you get dual run caps way cheaper than we do here in Phoenix for a retail customer! Seeing how this is a DIY site it could be that basheesh could have a meter. Not out of the realm of possiblily.
I am kind of old school like that. I was taught to never just swap parts till you find the offending one.
Old 03-05-12, 12:01 PM
B
Thanks for the advice. I will check the capacitor and see if that is the problem.
Old 03-07-12, 04:46 AM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
If the top of the capacitor is swollen it has definitely failed.
If it is not swollen it still may not be okay.
A swollen example...
