Mobile home Coleman AC freezing up
Old 04-18-12, 09:49 AM
E
My inside unit will run less than an hour before I háček to turn it off because the coils are completely frozen up. Compressor outside is fine. The fan works fine on manual so that I have some ventilation. The heater in system works great in winter etc. What can I do or have done. And will it be costly??
Old 04-18-12, 04:56 PM
C
Received 8 Upvotes on 8 Posts
May be low on freon, call an A/C tech to check it out. Make sure the filter is clean, the coil is also clean.
