Noise from central Heat and AC system
Old 04-20-12, 02:51 PM
K
Received 1 Upvote on 1 Post
I have Ruud system about 18 months hold. It has started emitting a steady noise, which I will call a "whirring" electrical noise. It does it constantly, regardless of whether system is set on "heat", "cool" or "off". The noise is just loud enough to be noticable and annoying. I know the noise is coming from the unit (the inside part - not the condenser outside) because it ceases when I throw the circuit breaker. Can anyone suggest what the cause of this noise might be or how to trouble-shoot it? Thanks.
Old 04-20-12, 03:05 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
could be a relay or more than likely the transformer.
Old 04-20-12, 07:15 PM
E
Probably the transformer. Try tightening down the screws that hold it in place, or loosening them to see if the noise stops.
