evaporator coild cleaning
Old 05-04-12, 07:19 PM
R
I want to do some basic DIY AC service tomorrow (in texas)
In addition to check on the drain pan and pipe, filter stuff, I want to use the no-rinse foam evaporator coil cleaner to clean the evaporator coil?
anyone has tips and concerns for DIY evaporator coil cleaning with no-rinse foam cleaner?
mine is a heat pump (all electric). it also has a float switch with no secondary drip pan/pipe
thanks
Old 05-06-12, 09:32 PM
user 10's Avatar
Received 57 Upvotes on 50 Posts
The indoor coil shouldn't require cleaning unless the filter has been neglected in the past.
