thermostate no display,how to find the fuse, transformer
Old 05-04-12, 08:58 PM
Hi, I am new here, and am looking for help.
I tried to replace my old thermostat to a new programable thermostat this afternoon, I was too excite to turn the power off, and the red wire shorted to some wire (didn't notice). then my AC was not working for the new thermostat, I checked the furnace in the attic, but couldn't find the fuse or transformer, the red LED is on. I put the old thermostat back, there is no display(the old thermostat doesn't need a battery).but the way,this thermostat is for downstairs, the upstair thermostat is working ,so does the air conditioner for upstair.
I read some post here, I believe the problem could be the 24V, but I don't have a multimeter at hand, and I wonder where the two thermostats separate,we have two units outside.
Thank you very much for helping!
I might be able to post some pictures here tomorrow.
Old 05-05-12, 05:16 AM
just checked. the fuse is good.
I couldn't figure out where separate the two thermostat. since one is working and the other not.
Old 05-05-12, 06:24 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
you should have 2 units inside also. Find the unit that the non working stat controls. From there locate the transformer and or fuse or breaker located inside.
Old 05-05-12, 06:52 AM
Thanks, I'll try to find the 2nd unit in the attic. what is the yellow wire for?
I saw the yellow and black go to somewhere else.
Old 05-05-12, 07:54 AM
checked that there is only one unit in the attic, the model is 58PAV.
Old 05-05-12, 08:09 AM
Thanks,
could my one heating unit outside too. what is the GS48024060?
Old 05-06-12, 03:43 AM
if you have 2 condensers outside (compressor/fan) you have 2 air handlers/furnaces inside hopefully the TR is fused or check the control board on the furnace might be there
