Repair or Replace ??
Old 05-07-12, 06:04 AM
D
I have a 5 year old split system (Goodman 2 ton) heat pump. Unit froze over weekend. Has a freon leak. Tech checked out unit. The evaporator coil is VERY rusted to the point where the metal is literally crumbling. This is only 5 years old. Don't know if it due to brand or other factors.
Per tech my choice is either pay for recharge and new coil (about $800) or new system. I asked why would I buy a new system (Carrier 2 ton split heat pump 13 seer Puron) for $5,000 if I could fix old for $700? He claims that if it leaks again it will cost me again in addition Freon is getting more expensive and may not be available in a year or so. At that point I will have to put in a new 410-A system if he cannot get freon.
I don't want to spend $5K but wondering if it is the wise choice. New system will have a built in Aprilaire Hepa filtration unit and a 10 year warranty on parts. The 10 year warranty is "limited" and I cannot find out what the limits are.
Any help is appreciated.
Old 05-07-12, 06:17 AM
C
Received 8 Upvotes on 8 Posts
Is it still covered by factory warranty ?
Old 05-07-12, 06:25 AM
D
Good point. 5 year warranty so it is a close call. I am not original purchaser and don't know exact install or purchase date. With Carrier warranty is NOT transferable. Don't know about Goodman.
Old 05-07-12, 09:55 AM
E
All you need is the model and serial number off the coil and call goodman and ask is this unit under warranty. I would replace the coil of it were me.
Old 05-07-12, 01:45 PM
2
I would replace it, it will save you the time and energy that goes in to repairs. Check on the warranty though, because you could end up not having to pay a dime!
Old 05-07-12, 02:34 PM
user 10's Avatar
Received 57 Upvotes on 50 Posts
There are drop in replacements for R-22.
There are all aluminum coils available now which resist corrosion better than copper/aluminum coils. (goodman is now 100% aluminum)
Get is fixed - it should have at least 10 years left.
Old 05-07-12, 06:29 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
R22 will be around for a long time. It will be expensive, but available.
