Where is re-set button on Rudd A/C?
Old 05-26-12, 06:50 PM
Z
I have a Ruud gas furrnace with air conditioning system. The Honeywell 3000 thermostat appeared to stop working. I added battery so I could see numbers on the display. However, the air conditioning unit doesn't come on, so I assume that there's a re-set button somewhere that needs to be re-set. Breaker in breaker panel and fuses outside with unit are good. There is not a re-set button outside on unit, so I'm thinking there must be one under house with furnace. I learned long ago not to assume anything and to try not to over-think things. Furnace is Ruud model RGTS-07EMAES, air conditioner is Ruud model UANL-03NAZ. Thanks for your help!
Old 05-27-12, 07:58 AM
E
assuming its getting 24 volts to the outside unit, the reset button is outside. usually right between the freon lines coming into the unit.
Old 05-27-12, 01:53 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Your thermostat likely has a 5 min delay before the a/c will run after it is turned on at the stat.
